Hello again, happy new year to everyone.
My cultus carb is killing me, averaging around 5.8kmpl. Loss of compression is ruining the driving experience. Drove my cousins cultus, the difference is night and day. After driving his, my own car feels as if it's accelerating =but going nowhere. (while that is obviously not the case it feels that way)
Irshad advised to keep driving until there is oil consumption. So no overhauling until then I guess. He did some adjustment to the car and said, drive and see how it goes, (did not go well) if it does then you're good, if not come back and ill have a carb specialist come take a look.
New issue has arisen. car stalls when brakes are applied. idle rpms are 800 when not accelerating and then stall when brakes are applied. Tested this while parked, idling fine at 800 and then I depress the brake pedal and then car threatens to stall, and then stalls. This is happening when car is fully warmed up to temp (idk how that may be relevant). when cold, doesn't stall all the way.
Cultus does not start, will crank fully but will not start unless I press the accelerator while starting and then let go after the car has started. If I constantly try to start it like a normal car without the accelerator, after the 3rd try it'll start but then immediately stall. When started, will idle at 750 until warmed up. if I rev while parked, idle rpms will come to rest at 1100, fall when I turn on headlights, rise when I turn on rear defogger, rise to 1500 and then fall down to 700 when I turn on the ac.
the heck Is wrong with this car, idk if its the vacuums or what I cant tell. Advice, ideas suggestions?
